spinergy said:Is it OK to fit a 13 amp socket under a bath to power a water pump also fitted under fitted under a bath? Thanks.
AdamW said:3) Installing anything electrical within 600mm of your bath is just totally wrong and possibly illegal.
supersparks said:im not sure its the best of ideas but, if you need a tool to remove the bath panel, I.e its screwed in place, then under the bath is considdered out of zones...so my understanding is that if you went on that it would be fine...i wouldent do it though...what if you had a leek down the side of the bath like so many people do![]()
would be better with an FCU outside the bathroom and a waterproof connection under the bath
AdamW said:Depends on the pump surely? A whirlpool pump is designed to work in this environment thus is adequately IP rated. A shower pump, isn't, so it isn't.Perhaps we need a better explanation of what the intention is, "pump" really isn't a specific term!
If you can't have a socket under a bath, then surely you can't put an IP X4 rated pump under there, can you?!
