This is driving me mad - busy 'prepping' the bathroom for new suite and working out what I need plumbing wise.
Going to use flexi tap connectors with built in isolation valves on the bath to save moving any existing pipework and want to do similar on the basin but this has monobloc mixer with copper tails so need 15mm to 15mm compression on each end of the flexi connector - do these exist with a built in isolation valve?
Or do I need to install iso then small length of pipe then connect the flexi? Would rather have just one compression joint than three if at all possible.
Cheers All
Cheers All
