Ok, perhaps a bit of an odd request, but is there such a thing as a 15mm street 'straight'?
I have a situation where I want to change a single panel radiator to a double. Right now, the pipework comes out of the wall about 80mm from the valves, into an elbow, 40mm of pipe, and then into the TRV/lockshield. The elbows are tight up to the wall right now, and the threaded entries on the new rad will be 16mm further away from the wall than before. This means that where the pipework exits the wall, it'll have to be extended by 16mm.
My fear is that an endfeed coupler is going to be a bit too long, although it would be ideal if there were a fitting similar to a street elbow but, well, straight! If it doesn't exist, I'll just have to trim an endfeed coupler as short as is necessary and make the joint that way.
