15YO boiler condemned as flue too long??? Please advise?
4 Jun 2007
London
Hello,
After fixing my Glowworm Swiftflow 75E I decided to get some insurance including a service and safety check.
So I did some investigation on the Internet and went for a deal with my current provider’s policy.
During the service I briefly spoke to the engineer on the phone, who said the flue is too long and there's no terminal. I then had to go to a meeting so didn't speak again. The engineer explained nothing to my wife who was home at the time.
When I got home there was a big red danger sticker on the boiler and a gas installation warning notice. Also, the service check list has not been completed apart from additional information regarding the flue length.
The maximum flue length in the installation manual (which I left available for the engineer) is 2833mm; my measurement of the flue, being VERY generous on both the wall thicknesses is 2740mm. The boiler is in a cupboard next to the bathroom and extends straight through the bathroom and outside wall (no bends).
The boiler has been installed in the house for the 11 years I have been there, and probably another 4 judging from the model.
Is the Engineer correct? I accept there's no terminal guard, which is easy to remedy.
4 Jun 2007
London
No bends it is a straight side flue as below.
Cheers
22 Jan 2007
On the face of it the engineer was wrong and ask the company to clarify. If you have no joy there then complain to Gas Safe.
4 Jun 2007
London
Many thanks, I wanted some advice before contacting the company.
Also, on the service record the 30 point check list hasn't been filled out.
Could this indicate he didn't do a service.??
Cheers
4 Jun 2007
London
Hi, I checked the flue terminal this morning and found that it had fallen behind the garden shed. I have now re-attached:
I'll also order and install a terminal guard and repair the rendering around the flue.
With the terminal problem sorted, should I go back to the company and ask for a second opinion about the flue length?
I quite sure it's within the installation manual guide lines.
Many thanks.
4 Jun 2007
London
It fits snuggly around the inner exaust pipe.
I also added a very thin layer of silicone, but was going to do some research on the heat/steam tolerance.
I think originally it was held in place by concrete. The entire installation looks a bit cowboyish to me. It happend when the property was council owned.
Is what I've done dangerous?
22 Feb 2012
Sheffield
Silicon is not a suitable material to hold a flue outlet together.
nor is a flue terminal held together by concrete
10 Jun 2009
Suffolk
In the time it took that Engineer to do all that paperwork (AR) he could have found the terminal, fixed it back with a couple of self tappers, measured the flue length to compare with MI's - if that terminal is less than 2 mtr from the ground it will need a wire guard this could be classified as NCS at worst, but then some companies see a boiler of that age and think pound notes!!£££££££££££££££££££££££££ :(
