I have just started using a brand new 18v Ryobi Jigsaw today, but every time the blade makes contact with the wood - the jigsaw cuts out.
I am using the Ryobi blades supplied and I also tried other blades to rule this out, but still the same thing happens. It runs ok in idle mode, but as soon as i start sawing - even small softwood 1inch thick with a 100mm blade (well within the dimension specifications for the blade) it still cuts out when it comes into contact with the wood.
The blade seems to fit in ok. And it's not loose, I even try to remove it after it cuts out, but the blade is still in position nice and firm and not possible to remove as it is still locked in ok.
I am using in 0 degrees setting too and approaching the wood slowly (it is by no means under any great stress).
any ideas what could cause this please?
I don't know if it is faulty or if am i doing something wrong.
thanks
thanks
