when the tenant is in there cooking etc, the moist air isn't being taken out.
Why is it not acceptable?Trickles are in the windows but I suspect he may be closing them to keep the heat in which is not acceptable.
Why do you think they fit closers on trickle vents?That is what they are there for. If the trickles are open 24/7 as they should be .
I know it does have one except it ventilates into the room for a start and there's no realistic way of hooking it up to outside.
I think you need to reconsider that option; it may seem unrealistic but maybe with some lateral thinking....
the current hood does take in and re-circulate dry air, it's not completely useless.
Recirculating cooker hoods do not remove any moisture. They only remove smells and grease.
I could rig up ducting to outside running it along the ceiling from the fan but it only works for as long as it's on.
The point is the humidity in the flat is high because it's a basement
