Hi all
Iv recently purchased a 20w LED security flood light from good old amazon
MEIKEE Security Lights with Motion Sensor 20W, LED PIR Floodlights, 2000lm LED Sensor Outdoor Light, IP66 Waterproof Outdoor Flood Light, 75W Halogen Lights Equivalent Replacement Warm White https://www.amazon.co.uk/dp/B079FHP8KW/ref=cm_sw_r_cp_api_i_nGOqFbEPAS7V2
I also extended the length with a waterproof junction box and 3core 1.5mm pvc cable and fitted a 13a fuse and plug and then simply plunged in to the outdoor waterproof 2 gang socket.
To make things more neater and save usage on sockets I’d like it to be connected to the outdoor socket, NOW I understand that you can’t wire in the light to any socket as the socket will be on a ring main (kitchen ring) so therefore I purchased a waterproof 13a FCU again from amazon.
Weatherproof IP55 Rated 13A Outdoor Fused Connection Unit (FCU) https://www.amazon.co.uk/dp/B00K73RHG0/ref=cm_sw_r_cp_api_i_xWOqFb1GA495W
So can a 2.5 t&e cable from outdoor socket to FCU be used then 3 core 1.5mm pvc cable from FCU to light be ok? Or should it be 1mm lighting cable from socket to FCU?
Is 13a fuse in the FCU overkill or will it need to be changed down to a 5a fuse. Would also at a later date like to add a second or third 20w or 10w led light added at some point to this setup.
The kitchen ring has a B32 30mA breaker in the consumer unit.
Thanks in advance.
