Good Morning all, I hope you all had a good weekend.
I am looking to partition off a corner section of our bedroom to install an en suit. We have an old Victorian house that has high ceilings, just under 3000mm. I am looking to have a stud wall running from the main outside wall into the room 2800mm and then turn a 90 degree corner and run to the other outside wall which is around 1400mm away. Each wall will reach from floor to ceiling and be tied into the joists top and bottom. Due to the height of the wall, would I be able to get away with using standard stud wall from Wicks (38mm x 63mm) or would i be better off using 4" x 2"?
Also, what plasterboard would be best to use on the walls for the bathroom and bedroom sides?
Would you also be able to direct me to the best place for buying the door surrounds?
Thanks in advance
Andy
Thanks in advance
Andy
