Winston, could you describe to the op how to go about soldering the 6mm2 T+E cable, as I am unable to give a good description.
and know how to do with even bigger stuff that 6mm conductors
Winston.No need. He is experienced at soldering.
Winston.
The op has done some 12v car wiring soldering.
He was not aware he could solder 230v cables.
He is not sure if the solder type varies between 12 and 230v wiring.
He has suggested using insulation tape.
Not ideal.
Would you be able to give a detailed description on how to correctly solder the 6mm2 cables together?
Others may benefit from this too.
[Citation needed]We are not supposed to give step by step instructions on these forums.
Odd, I'm often explaining things on this forum in the form of a step-by-step guide.No. We are not supposed to give step by step instructions on these forums.
Suffice to say electricians solder is the same for 12 or 240v, and so called insulation tape is not good for covering soldered joints.
Hi Ashbou.Hello, whats the best way to join 2, 6mm cooker cable together to extend it so i can move the socket. Will a yellow butt connector from toolstation work? The cable runs through conduit not chased inside the wall thanks
Why wouldn't I? After all, how else can I explain how to do something correctly?
Do you know what I think Winston?
I think you're full of shlte.
