WTF ... is it only properties with a straight rear wall that are eligable to apply for full width extensions, even where the existing projection is small, say 300mm to 600mm ??????????
Is this just daft, or am I missing something.
Could one make the wall straight to claim the PD ? ie demolish projections, where does planning law stand on that ? the PD Technical Guidance p19-28 sais nothing on this.
I note that you partly demolish a roof, where a full hip to gable under PD is built, although that PD is concerned more with Existing 'Volume' and Chimney Stacks and Finished Roof line.
Does the PD Right to extend the rear GF concern itself with whether the projection is existing or additional - I interpret things to say it does not, and any projection puts a stopper on a full width PD right.
Some detail:
I wish to add a 6mt full width extension on a 1930's semi, its original width is approx. 6mt, no additional extensions have been added at the rear.
I have successfully applied, had approaved and built a 6mt full width GF exteniosn on another property, the rear wall was straight.
On the current property a 600mm D (x 2400mm W) projection exists - which allows for a marginal increase to the kitchen area.
After reading through the following threads:
www.diynot.com
www.diynot.com
www.diynot.com
www.diynot.com
It appears 'any' projection out from the rear wall brings rise to a PN Refusal on any rear extension with reasons:
- the enlarged part of the dwellinghouse would extend beyond a wall forming a side elevation of the original dwellinghouse, and would –
- have a width greater than half the width of the original dwellinghouse
And indeed in the street, a number of identical 6mt full width extension applications have been refused, it appears a number though resubmitting PNs or full plans and gaining permission for 3.5 - 5.0 mt extensions.
All properties in the street have the 600x2400 extension to the kitchen (built with the original building, the properties all being identical), I have noted some applications omitting this 'projection' on the drawings, yet the Officers refuse and quote the above text, do officers visit the property prior to a PN application to check what is drawn is what exists ?
Here are some pictures to explain what I think I understand, might be allowed if no objections were made:
Some detail:
GDPO: Does going "Around" rather than "Through" a Side Elevation for rear extension
Hello, We want to do a 6m, full width rear extension under permitted development. Unfortunately, we have an attached coal shed, approx 1m x 1m attached to the rear corner of our house. This means that an initial "larger home extension" PD application has been refused as our proposal would have...
www.diynot.com
Side elevation or not
So just had an LDC refused as development not allowed under Class A, Part 1, Schedule 2 of the Town and Country Planning (General Permitted Development) Order 2015: (j)the enlarged part of the dwellinghouse would extend beyond a wall forming a side elevation of the original dwellinghouse, and...
www.diynot.com
Rear Extension to sidewall of existing rear extension.
Can someone help me understand this point, a prior approval has not been considered permitted development because its width would be more than half the width of the original house even though the width of the extension is not, only when they combine it with the width of the existing original...
www.diynot.com
Prior Notification Extension Proof
Hi I applied for a prior notification for a full width extension and the application was refused for the following reason. The council reckon that the side piece which I have marked in red is not the original house which is why they claim I am extending beyond a side wall If I was able to...
www.diynot.com
