this will happen with a high current passing through the fuse in the plug. the other components in the plug and socket can carry the current with ease, unless there is a poor connection, whose signs you will see when you open it.h
Does the flex near the plug get "hot" or does all of the flex get similarly "hot"?I had a new fuse-box unit installed a year ago and I use this plug socket every night for hours in the winter. Admittedly the flex and plug can get hot. As you can see the plug socket has cracked. It is about 45 years old.
I see no apparent signs of overheating, What I do see is physical damage such as being knocked (vacuum cleaner?? Baby walker?? etc) or a cable being tripped over. The damage is not recent, I assume the heater is left plugged in.I had a new fuse-box unit installed a year ago and I use this plug socket every night for hours in the winter. Admittedly the flex and plug can get hot. As you can see the plug socket has cracked. It is about 45 years old.
Should the fuse-box have cut the fuse out before it got to this stage of socket-cracking? I couldn't smell any electrical wire-overheating. View attachment 260667
Smoothing irons, hair dryers and electric drills are the main culprets in my book.the flex is not likely to get hot, unless it has been bent excessively and repeatedly, breaking the metal fibres inside. I have only seen that in electric irons which are constantly moving in use.
That doesn't look new.View attachment 262763 The story gets worse. An electrician replaced the cracked socket with a new one last week and tonight i could smell something weird from the fan heater/plug (which was hot) . The new socket has cracked as shown;
The crack and screw holes are already full of black dirt.
