As I said. Recommending fitting an rcd fcu 13a would be a fire hazard.
I know my preference. I have pointed this out.
Yes, when echoes' comment caused me to look again, I realised that - and, in any event, I'm not sure what I thought you would want 'three socket outlets' for!Thank you for your input. Sorry if '3 outlets' was misleading, I wasn't sure how to refer to them collectively - it was just to show that they will be tightly together, without long cable runs.
Dare I suggest?
Connect them both to the cooker outlet and change the fuse wire to 15A - and clearly mark the fuse as 15A.
I'm not sure where you are suggesting that this 'fire hazard' is coming from - perhaps you could clarify?As I said. Recommending fitting an rcd fcu 13a would be a fire hazard.
Yes, but if you did as EFLI suggested, there would be a 15A fuse in the CU (which is no worse than the 16A protection that the circuit would have everywhere else in Europe - where there are no 'plug fuses'). However ....Can I hardwire a hob flex? I'd lose the 13A fuse that the plug provides.
I think that you may have just moved EFLI's goalposts, by indicating why the CU fuse could probably not be reduced to 15AAnd we use the CCU for a kettle, so that would be 6kW with the oven on.
Can I hardwire a hob flex? I'd lose the 13A fuse that the plug provides. And we use the CCU for a kettle, so that would be 6kW with the oven on.
Kind Regards, John
Another suggestion (sans RCD)
Since your oven is 3 kW, you could use a plain Flex outlet for the oven + FCU with Flex outlet for the hob, both mounted on a twin back box. This arrangement would replace the Cooker outlet (where you currently have an existing socket.)
That sounds excellent
Apart from bare wires.
I thought there would be some loose wires while waiting for the fitter to fit the oven.
... The fitters will merely need to plug the hob into the 13A socket. ... Hardwire the oven flex to the cooker outlet plate - this will mean that the fitters will just need to snap the dangling plug into the rear of the oven.
