adding spotlights t ring main?
23 Feb 2007
Belfast
I am ading 4x 20W Lv halogen recessed lights in my floorboards. To avoid the hassle of reaching the lighting loop can i merely take a 20Amp JB off the ring main and add a 13 Amp FCU for the Supply to my transformer?
Cheers.
A better solution is to add the FCU straight to the ring circuit. If you can't manage that then a spur to the FCU will be fine but use a 30A junction box.
Make sure you fit the FCU with a 3A fuse.
Davy
Do you realise quite how hot these get?
There will be a real danger of severe burns to children with curious fingers, and a dropped newspaper or item of clothing will very quickly catch fire
LEDs are the only real option for floor mounting, and even some of these get suprisingly hot.
