Hello Forum!
Anyone able to give me some advice about work on a Combi Ideal Response 80?
A Brit Gas engineer (maybe a contractor not their own man?) said I needed a new expansion vessel and also PRV. I was forced to agree. Job done and billed. Later I tested the old EV and decided nothing was wrong with it. A visit from BG Service Mgr confirmed it was sound and they agreed to modify invoice. New invoice arrived and BG said quote<<< With regards a breakdown on the current, revised invoice, I presume that Dave has estimated the cost of replacing the expansion tank and reduced the invoice appropriately, as the majority of the labour charge would be associated with the pressure relief valve >>> unquote.
They had eliminated the (inflated!) price of the EV and left the labour at the same two hours. This seemed strange to me as the service manual suggests the work involved in replacing EV is much more complicated than changing the PRV and is really a separate exercise. In theory replacing PRV is just a matter of unscrewing the old one and screwing in the new one but the service manual says the pump must be removed to get at it.
Someone somewhere (on some other forum I think) said this might be a good deal less than an hour’s work for a DIY person.
Could any kind plumber who knows this combi give me an idea of the time involved in (a) changing a PRV and (b) changing the EV (there IS at least the required 600mm clearance above the boiler). In other words: does it seem unreasonable for BG to make the same labour charge for (a) without (b).
Don
Don
