Hi all,
First time post here, had a read through the alarm forum but had a question i couldn't see answered before...
We've moved into our new house a few months ago, and as part of the renovation I want to fit an alarm.
I'm currently looking at fitting a Texecom Premier alarm, and seem to have everything worked out apart from one bit...
The (internal*) front door of the house opens into an open plan living room, which also has the stairs in it.
I was thinking about having a contact on the front door, and also a PIR in the living room.
Question is, if the front door is opening into the living room, what would happen when the front door is opened?
Alternatively, is there a way I could get this to work with both the PIR and door contact?
* I noted internal front door, as we have a porch door that we walk through first before opening the door into the original part of the house. I suppose one option is to put the keypad in the porch and activate/deactivate the alarm from there, but the porch has a clear window which would make it easy to see a keypad in there, so i wasnt too keen on that unless it was absolutely necessary
All comments/suggestions are welcome.
desig
- If the door contact opens first, will that trigger the front door is open and give me the usual 20-30 seconds to deactivate alarm?
Or will the PIR also detect movement and trigger an alarm condition?
Or something else?
desig
