Am I allowed to change flow switch on potterton 80?
27 Nov 2010
London
legally? I have established I have the problem of the dhw flow switch sticking on (causing overheating and lockout) so it needs changing. Am I legally allowed to change this? I am not a heating engineer or gas safe. Not sure what the legal position is these days, years ago I would have just changed it, but more cautious nowadays.
I am no expert, but as far as I understand the answer is no. I believe you have to be registered gas safe / corgi or what ever the latest name might be.
If not I don't think you are permitted to work on boilers legally.
I could be wrong, but that's my understanding
yes a puma. So I can change it? I feel confident I can do so, although obviously I don't have test equipment.
thankyou
They rarely need to be replaced.
But some skills are needed to know how to fix and adjust them.
A new one also needs to be adjusted which is not that obvious either.
Not a very risky job apart from leaking water if you got it badly wrong.
There are also some live wires on some nearby components on some models.
Yeplots of towels there is a terminal strip just underneath where you will be cracking the joint!
