Now you've admitted that you were at fault she can sue the pants off you.![]()
A lesson in life...
Most companies/government organisations/individuals will ask you to 'make a small payment' in lieu of the claim...
If you agree, that by default means you are accepting some form of liability unless you state otherwise...
Again, going by what mkb has said, he has not done that...
Therefore he has left himself open to other sanctions!
Someone posted that the mediation was not visible to the courts, if that's the case then this shouldn't make a difference should it goto court. I would have thought that by default all mediation was without prejudice.
Could you then say with any confidence, that during a court case the actual fact that mediation had occured (whatever the outcome) would not be raised?Someone posted that the mediation was not visible to the courts, if that's the case then this shouldn't make a difference should it goto court. I would have thought that by default all mediation was without prejudice.
That is true, what ever the outcome of mediation, it cannot be used in any court proceedings.
Is it not a fact that at present if a judgement is made in court, the settlement is often dependant on what had previously been offered out of court?
If you can't remember the original facts of the alleged case, then (in your words) what's the point in answering again...Is it not a fact that at present if a judgement is made in court, the settlement is often dependant on what had previously been offered out of court?
Well that question was answered 35 minutes ago so if you cannot remember from that short time ago what's the point in answering it again?
