These MEM boards have a hinged and latched steel door, giving access to the main switch and the fronts of the MCBs sufficient to see them and operate the switches, and to see the labels or circuit identification list which is usually on the inside of the door.
Behind the door is a screwed-on steel panel which can be removed for maintenance, in the photos it has been removed, and gives access to the connections on both ends of the MCBs, and the earth and neutral bars. There is a separate cover over the supply connections of the main switch.
I think the pre-fire photos will have been taken during maintenance, when the screwed-on cover had been removed. It would be dangerous, and highly irregular, for the db to be in service without the cover.
My guess is that the overheating must have started, or worsened, fairly recently or there would surely be scorching or smoke marks in the casing that would be noticed during the periodic inspection.
View media item 1574
Something like this, though older ones may have a smaller central door with a metal latch.
