Yes, Gravity is only something that exists if you live on eath or some planet other than earh.
Or somewhere that is not a planet.
Sorry I feel bad. I shouldn't be splitting hairs, especially as the thread was an athiest pun.Yes, Gravity is only something that exists if you live on eath or some planet other than earh.
So light generates energy/mass which creates gravity.And just to confuse Vinty more, energy (like light) also generates gravity. Despite it having no mass, if has energy-mass which is what generates gravity.
If you fire enough light into a single spot at the right time you can form a Kugelblitz and make a black hole from light.
Exactly what we are sayingas gravity can extend over vast distances, i suppose on balance you could argue that it is exists all across the universe
A black hole isn't a planet but it still has mass which creates gravity.Or somewhere that is not a planet.
unconvincingA black hole isn't a planet but it still has mass which creates gravity.
That was the point i was making.
Correct, to be a planet it has to meet certain criteria.A black hole isn't a planet.
Yes they produce massive gravitational effects by bending space time.But it still has mass which creates gravity.
He is correct.unconvincing
There are gravitational effects produced by bending space time.Do you still maintain there is no gravity in the gaps between planets?
It does exist everywhere. If you pick any place in the universe there will be some gravity there. It might be very weak but it's there.So light generates energy/mass which creates gravity.
So therefor it is the energy /mass which creates gravity and not light.
No energy/mass means no gravity, as gravity can extend over vast distances, i suppose on balance you could argue that it is exists all across the universe.
I have always wondered where the dark go's when u turn the. Light on
He is correct.
gravity only exists on earth and other bits of stuff floating around in the universe.
Gravity is reality on earth, once you leave earth it does not exist.
Ask noseall, he's an authority on darkies.I have always wondered where the dark go's when u turn the. Light on
Thanks. But I think transam was referring to light.Ask noseall, he's an authority on darkies.
Mass creates gravity that was the point I was making.unconvincing
Which means you are indeed wrong. Gravity doesn't just stop, it gets weaker the further you are from any source. So If you pick any spot in the universe then it'll have some gravity there.Mass creates gravity that was the point I was making.
There could be lots of places in space which are gravity free.
