The tides are due to the moon's mass, not the earth.Gravity as we would understand it only exists due to the earths mass.,
No it doesn't. Gravity is a measurable by product of bent space/time. We can see its effects exhibited as gravitational lensing , where we can see "behind" things, such as behind stars.Gravity only exists to where your are in time and space.
The bent space also changes the relative speed of time (so time spent in different gravitational fields passes a different speeds). This happens with the clocks in GPS satellites- they run faster than the same clocks on the planet as there's a weaker gravitational force / faster time, compared to grpund level. It's minisucle, but, enough to require correction or it cocks up the GPS calculations.
I dont follow?Before the big ban
No, it's still there.Gravity is reality on earth, once you leave earth it does not exist.
