Completely off the topic at hand, but I have a sizeable (several thousand) collection of LP's, 45's, EP's, and 78's, so I'm certainly planning on continuing to use them for the rest of my days.Yes, I still have and use a turntable.
I've got two.
Wot's the difference? I have a fair number of 7" (I think) 45s, but I call them EPs!45's, EP's
EP = Extended Play - More than one track per side, as opposed to the 45-rpm "single." Most EP's are also 45-rpm discs, but there were some 33-1/3-rpm 7-inch records made. Some manufacturers also called those EP's while some called them mini-LP's.Wot's the difference? I have a fair number of 7" (I think) 45s, but I call them EPs!
Or one long track. I have one which is around 9 minutes on one side, 7 on the other.EP = Extended Play - More than one track per side, as opposed to the 45-rpm "single."Wot's the difference? I have a fair number of 7" (I think) 45s, but I call them EPs!
I forgot to mention those! One long track was also common on some 10 & 12" LP's for soundtrack albums, long medleys etc.Or one long track.
A later (1950's era) 78 in good condition and played on decent equipment, perhaps with a little filtering, will blow away an MP3.Then there are 12" 45s, and a good one of those played on a good system will make a CD fan weep, and an MP3 download user utterly confused.
I totally messed up my question!! I obviously wasn't talking about 45 rpm 'singles', of which I have countless. I don't know what my mind was up to when I typed, but I meant to ask about 7" 33 rpm ones, of which I have quite a few (mainly with two tracks per side, occasionally more and sometimes just one long track), and have always called "EPs". However, I guess you have answered the question I meant to ask, by mentioning 7" 45 rpm "EPs".EP = Extended Play - More than one track per side, as opposed to the 45-rpm "single." Most EP's are also 45-rpm discs, but there were some 33-1/3-rpm 7-inch records made. Some manufacturers also called those EP's while some called them mini-LP's.Wot's the difference? I have a fair number of 7" (I think) 45s, but I call them EPs!
I have quite a few as well. They seemed to be popular with some of the smaller/cheaper labels in the 1960's to release about half a dozen songs on a 7-inch disc. They were certainly common enough that by the late 1960's some of Garrard's turntables which had the combined manual speed/size selector arrangement included the 33-rpm/7-inch combination (even though they'd dropped 33-rpm/10-inch!).I meant to ask about 7" 33 rpm ones, of which I have quite a few (mainly with two tracks per side, occasionally more and sometimes just one long track)
The Utube link does not really show if official Which or just an advert for her firm.
The logo on the video shows a question mark with the dot on top.
The 'Which?' website shows the dot at the bottom in the conventional way.
http://www.which.co.uk/about-which/
