Im going to be redoing the kitchen at the end of the month.
the only electrical changes im making are to the oven and hob.
its a double oven and the total load is 4.6kw
the hobs load is 6.5kw
so a total of 11.1kw
1) Am i right in thinking i will need a 10mm cable from the consumer unit to a cooker switch?
2) So i will have 1 10mm cable going ot the cooker switch and 2 10mm cables coming out, one to either appliance?
3) Instead of using a 10mm cable to each appliance could i use 2 6mm (one to each)?
4) Will a 40a mcb be ok or should i use a 50a?
last questions.
5) Should put it on the rcd sid eor the non rcd side?
thanks in advance
chris
last questions.
thanks in advance
chris
