Hello guys don't shoot me down here just wondering if i can do this myself safely rather than pay x amount to an electrician plus i get some man points if i've done it well.
So im planning on having sockets in the loft 2x doubles to be exact. I will also be running cat6 cable at the same time so now is the best chance i have to get it done.
I lifted up the floorboards in the bedroom below to get access to the wiring and i found two 2.5mm wires running into a junction box then onto a socket from there daisy chained to a further 2 double sockets. First of all is that safe? Looking at the back of the sockets there is 6wires in the first socket 6 in the next on the chain and six in the last, it then goes back to the junction box.
Am i right in thinking this has been done as a ring main?
Next question is.
I have taken out the old electrical heaters in two rooms and pushed on terminals to the wiring and then disconnected it at the CU by pulling the RCD out.
I have checked and its not a timed circuit as is common for heaters, so i think i would be able to put a junction box on that and take the wiring up into the loft for use with my sockets.
Would that be the better way of doing it and safest all round? I would mark on the CU that i'd changed it also.
Thank You
Next question is.
Thank You
