Bought a 10.5kw unit to replace old 7.5kw. Replaced 6mm cable run with 10mm then got a spark in yesterday wire it all up.
I have a couple of concerns about the work he did and would appreciate any advice.
1) 10mm runs from shower to 50a pull switch to 40a RCD, but the spark did not replaced the old 2 inch long 6mm cable between the RCD and the power switch. Will this be ok?
I feel that the run is from the power switch to the shower and this 2inch piece is effectively creating a weak link in the run, and the fact that it is on the power side of the RCD means that if there was a problem the RCD would not trip. Am i right to be concerned.
2) The old shower had an additional 2 earth cables attached to the unit as well as the twin and earth. Not sure where these go. The spark has not used any of these and has only used the earth in the 10mm cable. Should the new setup use the same amount of earths as the old?
One top of this the shower does not work properly. The old shower had plenty of power/pressure but was a little cold in winter hence the upgrade. The new unit has power to it and the water is turned on as before but all we get is a trickle of water through the hose and there is no heat in it at all. We did switch it on initially with the sprayhead attached but I'm sure the PRD did not blow as there is not any water coming out of it. Sprayhead now removed but flow pressure is terrible. Just removed the unit from the wall and water supply and turned the water on, it hit the ceiling so I don't think the ingoing pressure is a problem.
If anyone can help with any of this I would appreciate any advice and comments
Graham
Graham
