Attaching earth to brass banjo?
1 Sep 2015
I've got to the point where I am earthing inside a plastic housing and I need to earth my Swa gland.
I know I need to crimp the earth and the screw and nut it to the banjo, but can anyone point me in the right direction for a 20S?
I read that you can't just use any metal bolt and lug. The only places near me are screwfix, toolstation and b&q
Thanks I was looking at those also.
What size crimp do you suggest for those?
I mount the gland to the box with the banjo trapped between the box and the gland and drill a hole straight through, fitting a brass M4 screw on the outside and a flylead to the E terminal and nut on the inside.
With an extra locknut presumably on a plastic enclosure (as the OP has)?
Many banjos have an M8 hole these days, even the 20mm ones. Stupid! You can get M6, M8, M10, M12 brass set screws/nuts from most wholesalers. Many sparks use galv roofing bolts (cable tray etc) for the banjos, but this is heavily frowned upon.
You must use a better wholesaler than we do!
I have not done a vast quantity of SWA- plastic jointing: every day's a school day as they say.
