The 1st time i changed a back boiler for a combi i took the back boiler an gas fire out. Is it ok to disconnect the flow and return to the back boiler and leave it in so i dont disturb the gas fire
corgiman said:i would leave the flow and return open as well
but who in thier right mind would want to keep a fugly BBU fire??
Alfies Revenge said:The 1st time i changed a back boiler for a combi i took the back boiler an gas fire out. Is it ok to disconnect the flow and return to the back boiler and leave it in so i dont disturb the gas fire
Bambergaspipe said:I`m surprised at the advice you are being given on here.
Bambergaspipe said:Alfies Revenge said:The 1st time i changed a back boiler for a combi i took the back boiler an gas fire out. Is it ok to disconnect the flow and return to the back boiler and leave it in so i dont disturb the gas fire
The answer is ``no`` the back boiler & fire are one unit you cannot completely disable the back boiler gaswise, if you have gas feeding the fire it passes through the same valve feeding the back boiler. You have to turn off & isolate both. I`m surprised at the advice you are being given on here.
ollski said:Bambergaspipe said:I`m surprised at the advice you are being given on here.
So am I now....what do I do with all my disconnected bbu stickers?
Bambergaspipe said:ollski said:Bambergaspipe said:I`m surprised at the advice you are being given on here.
Shove them up your a*a**e![]()
You are obviously an ignorant buffoon, how is the bbu disconnected if the fire is still live![]()
If you are leaving gas fires on connected to back boilers you are breaking the Law. Unless you reroute the gas supply to feed the fire only.
Has anyone done their acs around hereOllski obviously has not.
corgiman said:Where do you get these stickers matey I have never seen them??
ollski said:corgiman said:Where do you get these stickers matey I have never seen them??
Company stickers![]()
My answer remains the same, take it or leave it.![]()
