Balancing a radiator system that only seems to work in reverse ?
It worked for me after numerous other methods failed. All radiators are now working fine and
( if required) raised or lowered in temp by adjusting the TVR only and not touching the lock shields the other end which remain fully open
So, if you have the TRV's open to maximum, because you want the heat, then all rads have both valves fully open? That isn't how to balance the system.
