    Dismiss Notice
Bathroom Fan Isolator inside a Fixed Bathroom Cupboard
Discussion in 'Electrics UK' started by Jillofmosttrades, 2 Oct 2012.
  1. Jillofmosttrades
    Jillofmosttrades
    2 Oct 2012
    20
    Thanks Received:
    London
    Country:
    Hi Diynot-ers
    Long time lurker, first time poster here. Would really appreciate your thoughts on the following.
    I am installing an 240v ip45 fan extractor in zone 2 of my bathroom. (suitable for purpose)
    My question is regarding the isolator switch. Normally of course I would install this outside the bathroom, however, given the interesting arrangement of electrical install in my bathroom the switched and permanent live for my lights are all accessible in a junction box sealed behind the fitted vanity sink unit.
    With a bit of jiggery pokery it is possible for me to gain access to this and potentially to fit a double pole switch inside this cupboard, potentially negating the need for me to rip up my bathroom to stick the isolator outside the bathroom.
    My question is this. Strictly speaking of course - inside the cupboard is outside all zones of the bathroom so therefore I should be able to put my isolator there - I think! and I can't find anything to specifically say no I can't do that in the 17th - except for the lovely vague 'external influences'.
    So what do you guys reckon? Can I, or can't I? and as an added precaution has anyone come across a IP rated double pole isolator I could use?
    Thanks very much for your thoughts guys!
  2. Sponsored Links
  3. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    You mentioned switched and permanent live - is a DP isolator enough?
    Inside the cupboard will be fine for a normal switch, but if you really want an IP rated one look at MK Masterseal.
    • Thanks Thanks x 1
  4. Jillofmosttrades
    Jillofmosttrades
    2 Oct 2012
    20
    Thanks Received:
    London
    Country:
    Hey there Mr Sheds,
    Thanks for the reply! I believe a DP isolator is suitable for purpose. The fan has an overrun so I need to make sure I can isolate both lives - I'm pretty sure a DP isolator is the way to go with that...
    So you reckon that sticking a standard switch in the cupboard won't violate anything in the 17th? I can't see why it would, but you never know?...
  5. xr4x4
    xr4x4
    1 Oct 2009
    3,159
    Thanks Received:
    290
    Hampshire
    Country:
    What about the neutral? It's normal to use a fan switch.
    That will isolate neutral, live and switched live.
    • Thanks Thanks x 1
  6. Jillofmosttrades
    Jillofmosttrades
    2 Oct 2012
    20
    Thanks Received:
    London
    Country:
    Hi Paul,
    I'm sorry - a fan isolator is indeed what I mean when I say DP isolator, so yes, absolutely neutral too!
    What do you reckon to putting it in the cupboard?
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    That'll be a 3-pole isolator then.
    Never seen an IP rated one.
    It'll be fine in the cupboard.
    • Thanks Thanks x 1
  8. Jillofmosttrades
    Jillofmosttrades
    2 Oct 2012
    20
    Thanks Received:
    London
    Country:
    Ah ha! Perfect - many thanks boys!
  9. securespark
    securespark
    11 Jan 2004
    34,430
    Thanks Received:
    1,064
    Country:
    • Thanks Thanks x 1
  10. Sponsored Links
  11. Jillofmosttrades
    Jillofmosttrades
    2 Oct 2012
    20
    Thanks Received:
    London
    Country:
    that
    's an idea - belt and braces, you know! :)
  12. Jillofmosttrades
    Jillofmosttrades
    2 Oct 2012
    20
    Thanks Received:
    London
    Country:
    Hello again Folks,
    Seeing as you were very helpful last time I thought i'd ask another question.
    'Someone' has advised me that I need to protect the fan with a FSU.
    It's connected up in the standard way - onto my lighting circuit, on 1.5mm cable protected by a 6amp MCB (also RCD protected).
    Why on earth would I need to give it an FSU as well?
    I just sort of rubbed my chin and said 'riiiiiight' and thought i'd ask you lot for a second opinion....
  13. RF Lighting
    RF Lighting
    31 Mar 2006
    19,303
    Thanks Received:
    1,249
    Leeds
    Country:
    The manufacturers instructions usually require you to install an FCU as a covers all soloutuion incase the fan is fed from a socket circuit or whatever.
    As long as you're supplying it from a lighting circuit and you have your 3 pole isolator installed, then you're good to go.
    • Thanks Thanks x 1
  14. Jillofmosttrades
    Jillofmosttrades
    2 Oct 2012
    20
    Thanks Received:
    London
    Country:
    I'm liking that answer = i'm glad i'm not missing something! Cheers!
  15. 17thman
    17thman
    29 Jun 2008
    834
    Thanks Received:
    46
    West Midlands
    Country:
    some manufacturers ask for 3amp fusing with extractor fans and when you have switched and permanent live it gets annoying.
  16. EFLImpudence
    EFLImpudence
    7 Jul 2010
    32,230
    Thanks Received:
    3,494
    Retired to:
    Country:
    Portugal
    I haven't read the whole thread but...
    apparently it is acceptable to only fuse the permanent live as it is only this which actually feeds the motor.
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
