Bathroom mirror with dimmable LED light rewiring
21 Feb 2009
Warwickshire
I have a bathroom mirror with a sensor to activate a dimmable light that is cool white and warm white.
I have not done a huge amount with LED strips.
The strip is connected to the controller with two black at W-, two red at Out+ and two white at C-.
What I want to do is to remove the controller and connect straight to the driver so that when the power is applied the light comes on - which it does not do presently due to the sensor.
I think what is happening is that the two black are for cool white and two white for warm white so I would select which I want to go with and connect them to the positive on the driver.
But, I wondered if anyone with more experience could confirm please?
Thank you
LED strips are generally common positive, with negative connections to the various colours.
Yours being negative to W- and C- for warm and cool
with red as the common positive.
Thank you very much. So just so I am clear if I want the warm white I would connect the two reds as out+ to the + on the driver and the two blacks at w- to the - on the driver and I should be in business? Thank you again
