- Joined
- 17 May 2012
- Messages
- 10,790
- Reaction score
- 852
- Country
OK, so it's finally bathroom refurb week*.
The bathroom has 2 walls that are battened with plasterboard+tiles - I am removing board and tiles today. Behind this is about an inch (maybe less on this wall) of plaster, then brick. The other 2 walls are just tiles on inch plaster.
I was going to take the whole room back to brick, but now thinking that as this wall, which was external but now internal, has hot& cold pipes and a shaver socket (basin is on other wall) I thought maybe I could keep the battens and just board and skim / paint (I plan to tile just around the bath).
I was expecting the battens to be rotten and the wall to be much worse, but I get the impression this job is not actually all that old, maybe less than 10 years (spare tiles were in the garage when we moved in 4 years ago).
One thing, sometimes I hear creaking noises which I think is from the heating, but could be these pipes, as they are in tight against the wall and the wood. So if I take back to brick, I could box in that corner, with the socket moved left a bit, and shove some insulation around the pipes to reduce noises.
But I would be easier to just leave as is.
The external wall, second photo, I will be taking back to brick, as I need to insulate that and board, and not enough room to do it on top of the inch of plaster.
*I'll probably only get the demolition done, maybe some boarding ...
