Hi all,
Does this sound okay?
I have refitted the bathroom and removed the electric shower. I removed the wiring that was going to the shower back to the loft and want to terminate it to use it for 2 mirror demisters and the extractor fan. This new circuit will be all switched on/off by the previously installed double pole isolator pull cord switch that was put in for the shower.
I plan to either use a fused spur to connect the heavy flex to the 3 components or maybe use a 13A RCD like this http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A231858&ts=88267&id=83049.
Point to note, all the electrical joins will be in the loft, there is enough double insulated flex on the demisters to do a continuous run to the join in the loft. This cable will be in conduit channels that will have tiles/mirror over.
Does all this sound okay or have I missed something (other than part P stuff). The original shower circuit goes back to the consumer unit to it's own trip switch circuit.
Thanks for any pointers peeps.
Glen
Glen
