- Joined
- 2 Apr 2022
- Messages
- 22
- Reaction score
- 4
- Country
Hi I’ve just moved into a house with one of these boilers. It broke down after 3 weeks and I had a plumber out who replaced the fan (after 10 days without heat). That was in Feb…it’s been repaired about 2-3 weeks and it’s gone again today. Obviously I’ll be calling them on Monday but I was hoping I could do something over the weekend because it’s quite cold!
Basically the boiler light is on but the fan and pilot lights are off. Thermostat is up, pump on water tank upstairs is running…just that it doesn’t run the usual starting process and fire up. When it went last time it happened sporadically before going permanently. Then I could either turn it down to reset and it would start or turn it off at the wall then all back on and it was fine.
After the guy fitted the fan it actually didn’t run immediately he poked around in the PCB and it fired up. He then said it might be the pcb ‘but it definitely still needed a fan’….I’d actually read lots of q&a here before he came and I suggested it could be the pcb when he arrived but he said fan because no fan light on.
My question is, is there anything I can do short term? I’m happy to replace the pcb but that won’t arrive til early next week when I hope the plumber will return.
There’s loads of other issues with the CH but I’ve gone on enough for now!
