bearing for steel?
so do you say a 254uc is over specified over 7 metres,
do not want to argue the toss, unlike some so called professionals on here, so hey ho.....
No, the reactions stated above would equate to 20kN/m which is about the limit for a 254UC for that span.. but lets not go off topic
whatever size steel.... it can sit on whatever sized wall it is designed to
100mm bearing is sufficient.
the 150mm statement throws people into panic...
how thick are your walls...
100mm
so how can your steel sit 150mm on a 100mm wall
mininum bearing for steel on masonry is 150mm but you could be comfortable with 100mm if it was for a doorway. The only time it would be less if it was say a precast concrete slab onto a steel beam and you could have 75mm.
100mm
more tosh.... but hey ho... waiting to be proved wrong.....
