Due to a new fitted bedroom wardrobe I have just 58mm between the front face of the wardobe and the door frame, which isn't enough for the standard light switch that used to be by the door (the narrowest I've found is 75mm). There's no obvious place to relocate it to.
An architrave switch would fit of course, but not only is the space in the pattress box very small, but I did also have a 2 gang 2 way dimmer here (200W & 150W branches) and i would like to keep 2 gang and preferrably dimmer as the lights for the wardrobe area are separate from the bed area.
It's a studwork wall. Can I legally make a bespoke pattress box and modify a standard 2 gang dimmer switch to fit by trimming the sides off and making alternatives fixings for the switch plate?
The only option to keep a standard switch is to move the switch onto a 15cm wide strip of trim at the the end of the new wardrobe. The rear of this would be in the wardrobe, so would at least require careful sealing if this is allowed? Of course this trim is flamable (chipboard) and the dimmer switches do get quite hot.
