I have fitted a new veritas excel alarm system in the house. All has gone well. For the front door (exit/entry) I have fitted a PIR instead of door contact as it was easier for me to hide cable. I am ok with this but just concerned any post coming through the letterbox, light reflections from kitchen at end of hall may set it off. Will fitting a dual tech (DT) pir be a better option and less likely to cause false alarms ?
I have also fitted a pir in the conservatory. The electrical shop where i purchased alarm gave me a Texecom Reflex dual element pir. Is this suitable for this environment or should i change this for a DT ?
For the Dts i am looking to get the Texecom Prestige DTs, good choice ?
Do you know what is the minimum distance the microwave range can be set on this model ?
Thanking you in advance.
