A stud wall sounds hollow when you tap it.
it'll be stud then
That is certaily a possibility if it is a stud wall.no idea what a stud wall is so cant answer that. i think its plaster. there is a switch there already actually for the landing. i could make tht a double and add this in?
Very probably the easiest to install, but much more likely to 'go wrong' than a simple switch.....but wireless feels the easiest?
Best way to turn a pull switch into a normal switch in the bathroom
Kind Regards, John
If you were going to have the switch outside (maybe in combination with the present landing one), you wouldn't even need to do that - none of the wiring would be inside the bathroom.i could always drill through the window frame at the top too...dont even need to go through the wall
Kind Regards, John
Yep, something along those lines.so this means picking the wires up in the loft and then drilling down through the loft and latching onto the existing switch (but turning it into a double).
Hi SS
What is that a photo of? Is it a wireless switch? Which one?
