This
is the problem, solar panels are not expensive, so if someone has money with which to buy 'balcony solar'' kit, no longer means they have the money to do other things we would normally think should be done before starting. Rated 300 watts including inverter, it says made by Parkside, so assume German Lidi.
8 way consumer unit, £48.48, RCBO £28.14 so £273.60 for a CU populated and that is without SPD. By time fitted looking at over 3 times likely 4 times the price of the solar panel to have a CU which will work with it, considering Part P means £100 plus vat to DIY and get is pro fitted not much difference. He showed picture of the CU
so to be within a reasonable price, only options to have RCD protection is a RCD socket or FCU, or the price means he will use without RCD protection.
It is very clear he is not fitting a new CU, not sure that he could even if he wanted, the question of rented of owner occupied has not been asked, for a tenant to swap a socket OK may be not quite what he should do, but likely he can get away with it, but to swap a CU is a non starter.
In the past this
was the answer, advert says type AC but picture shows
so looks like type A? It is not really any good as active type, but nothing shown on the data sheet shows it to be unidirectional so it may be OK.
But other than that can't find any RCD suitable for DIY fitting.
