One venue was hosting the clash of London’s football titans while the other was a sleepy Yorkshire village that hosted a famous battle more than 900 years earlier.Unfortunately for Earl Spencer’s
www.thetimes.com
Yes, some good examples there of "not doing any basic sanity checking".
Unless it's somewhere I've been before, I zoom out on the sat-nav and look at where it's taking me. Is the destination even in the right direction ? Such a basic check would have stopped the young lady being taken to Yorkshire instead of London - you don't need much screen resolution to tell the difference ! It would also have stopped some fo the other cock-ups listed.
As for the stuck lorry, that's a common problem of "information not sufficient and system not applying "nouse".
Near me there's a little narrow road - perhaps only 100yds long. It's one that locals know not to use, it's barely wide enough for a small car. But a sat nav doesn't know that, so for many uses - such as an unfortunate Amazon delivery driver - it's the shortest route by a long way between buildings at either end of it. SWMBO used to keep an eye on a second home next to it - one day we were there to check round, and we found a stuck van. The driver was getting a bit panicked as he had no mobile signal and couldn't get out as the walls either side were too high. He did have the sense to reverse out as soon as he saw how narrow it was - but at that point, his engine expired leaving him stuck. For good measure, a stone had chocked his front wheel so he couldn't even roll down the hill to where the wall was a bit lower on one side. I was able to shift the stone, he rolled down a bit more, got his jump leads out of the back, but it wasn't going. If I'd had my Land Rover on the road at the time I'd have considered getting it and pulling him back up the hill - but as it was, we had to leave him arguing with Amazon once he got to where there was a phone signal.
When you unfold a paper map to see a larger area you do not lose detail.
Indeed, but if you want a large area
and high resolution, then you end up with an impractically large map. Anything larger than the (I'm guessing) A0 sort of size used for the OS Landranger (1:50,000) maps gets very awkward to use - especially if in a confined space (e.g. in a car or small aircraft cockpit), or outside where the wind will be doing it's best to separate you from it. So when you get to the 1:25,000 maps which show every building, field boundaries, and so on (so really useful when off the roads) the area covered is much less and there's a lot more sheets to cover the UK.
Back when I was flying, we tended to use the half-mil (1:500,000) charts which cover the UK in three sheets. There's the 1/4 mil (1:250,000), but then your route crosses multiple sheets and it's harder to manage even though they show more detail which is useful if flying at lower altitudes. But even if your route only uses one sheet, there's a definite knack of how to fold the chart (while still on the ground) to make it possible to use in the air.
