I need to move (and replace) the Boiler from the (downstairs) kitchen to the (upstairs) airing cupboard. The cupboard is 500mm wide but 1200mm deep. Ceiling is normal 8ft. It seems sensible to have the hot water cylinder on the floor and the boiler above it.
All the diagrams I've seen show the boiler below the cylinder with the pump mounted at about half the cylinder height.
Is it possible to do what I want and if so what height should the pump be at.
By the way, the F&R tank (and Cold water tank) will stay in the attic.
