Good morning all.
I currently have a Potterton performa 28i, which has a couple of problems, most notably their is no hot water delivered to the taps (I believe this is a problem with the valve, as opposed to the switch, though I'm not 100% certain), and the device that's filled with air to help regulate the pressure is broken and currently full of water.
I had signed up with British gas home care, on the miss-understanding that they would fix all of the problems with the boiler (I signed up to the years option at 30 a month), however once I was told that each additional problem was an additional fee, I decided I'm fed up enough to just be done with it and upgrade/replace.
My current desires on the replacement are as follows, but if I'm missing some thing please enlighten me
1) Easy to repair, I've been told that the Potterton, though not exactly a bad boiler, when it comes to repair work, it can be quite cumbersome and as such bumps the labour charges quite a bit.
2) Big enough for the house (I'll get to that in a bit).
3) Reliable
4) Parts are not extortionately expensive.
I'm not sure if all of the above is reasonable, however I thought it would be a good starting point
I've been told that the manufacture Valiant is a reasonable boiler that fits at least 1 and 3.
It is a 3 bedroom split level council house, on the top edge, so I have a roof and three outside walls. rough bedroom sizes are 3m*4m, 3m*2m and 1.8m*1.8m. The down stairs covers roughly the same area (including kitchen and bathroom. The house has single glazing and wooden floors (or will have once we've finished!)
The current boiler is 29.4Kw, I believe this was reasonable, as when every thing was working, the hot water for the shower was hot, and the radiators hot (till I mucked up the balancing that is, I learn some thing new all the time).
I was looking at one of these two boilers,
Vaillant ecoTEC Pro 28 or Vaillant Combi Gas Boiler 831 EcoTEC
However, I'd like to know the experts opinions on these boilers.
If i've left any important information out, I appologise in advance, I'm far from an expert, so let me know and I'll ferret it out
3) Reliable
