Bonding
26 Nov 2013
Cornwall
My consumer unit is split and has two RCD's protecting all the circuits.
The main earthing is a single cable from the main earthing terminal connecting the gas and incoming cold water.
I have a combi boiler, but I cannot see the any hot water pipe earthed.
Is that normal?
Thank you. I have a main earth coming in from the electricity provider. This goes to a terminal block. From this terminal block, an earth goes to the consumer unit, and also a separate earth goes first to the gas pipe and continues (unbroken) to the incoming water supply. It basically looks like the picture on your link.
I suppose I am thinking about the hot water pipe coming from the combi boiler (and come to think about it the radiator pipes) as I cannot see any earth on these???? Are they needed???
Thank you. I have a main earth coming in from the electricity provider. This goes to a terminal block. From this terminal block, an earth goes to the consumer unit, and also a separate earth goes first to the gas pipe and continues (unbroken) to the incoming water supply. It basically looks like the picture on your link. I suppose I am thinking about the hot water pipe coming from the combi boiler (and come to think about it the radiator pipes) as I cannot see any earth on these???? Are they needed???
The (only) purpose of the main bonding is simply to ensure that any pipe entering your house from outside is at the same potential as your installation's earth terminal, and hence the 'earths' throughout your installation (i.e. to ensure that a potential different from that of your installation's earth is not introduced from outside the property by pipes entering the property). Any other pipework which is wholly within your property cannot possibly introduce any other potential ('from outside') and therefore does not need main bonding. In practice, of course, if your house has copper plumbing, all of the pipework will end up effectively 'electrically joined', anyway.
Kind Regards, John
The need for supplementary bonding (eathing) to hot/cold/rads is negated by the fact that all your circuits have RCD protection
So no, it's fine
SB
What happens if RCD fails and there is no supplementary bonding in place.
Well, that's certainly one of the conditions for omitting supplementary bonding in special locations. However, I suspect that the combi-boiler which concerns the OP is probably not in his bathroom, anyway.
Kind Regards, John
Thanks everyone.
So I take it that the hit water and central heating don't need "bonding".
Combi is in kitchen.
