Burnerman where art thou? Stihl Combi query
23 Feb 2007
Belfast
I have bought a stihl combi as spares or repair because i wanted the attachment that came with it and will use the head unit as a parts donor for identical one i'm running currently.
It's a KM130 and about 4/5 years old.
I would ideally like to get it running as a spare unit if it wasn't that hard. It has a spark but has some fuelling issues and is currently not running.
The primer bulb does not fill when pushed but after pumping it the plug is wet so its getting some fuel. I am assuming it has been messed about with as the adjustment screws are wound right in.
Can i get a carb re-build kit and more importantly do you have any info on default carb screw settings?
Thanks and any ideas/ pointers welcome.
My apologies for missing this one....it could be something to do with a hedonistic week in Ibiza :P
The primer bulb is to fill the carb with fuel - as you realise there isn't any float chamber on these due to the fact they can be used upside down.
Two faults occur with the primer system 1) The bulb doesn't pump juice 2) the bulb sticks in when depressed.
Both of these problems can be sorted by replacing the diaphragms within the carb - but please be aware the drillings within are minute and really need compressed air and a can of carb cleaner to sort them.
The first (pump) diaphragm is under a cover with a central screw. The diaphragm has a spacer gasket as well - don't forget which way round they go!
The second (metering) diaphragm is under a cover with 4 screws usually - and the same technique applies here.
Regarding the adjustment screws, usually the settings are printed on the air filter cover, but if the screws are black with springs visible then 1 turn out on each should get you going. The screws are marked L and H in this case.
If the plug is wet, turn the engine upside down, and pull the recoil cord until any residual fuel is dispelled from the crankcase.
The carb is likely to have a number - often C1Q and 3 numbers after. Use this to get new diaphragms or take the carb to a Stihl agent.
Hope this helps!
John :)
The bonkers show was probably in the Newcastle airport departure lounge :shock:
'Roxannes Hen Party 2013' claimed the T shirt.....came back with tomb stones in their eyes!
Moi - living it up with the other old crocks in Sta Eulalia :P
Hope you get the carb sorted - plenty of non Stihl replacements from the likes of GHS on ebay.
John :)
