It'll be in the book of words - Bypass rads are no longer an acceptable method for bypassing boilers and I don't believe the 8000 has an internal bypass.
If there is a possibility of the pump pushing against a closed head - all the valves in the system are shut down - then an auto bypass would be required to ensure min flow through the HEX on overrun.
