Will be installing 2 Sodium Lights 70w and 2 external spot lights for some shop signs.
The total distance is 30m and 1.5mm cores will be sufficient.
The only thing I cannot decide on is the cable type.
All the cable is to be clipped direct, half in a 'covered' area about 4m up the rest runs externally approximately 4m at the highest point and 3m at the lowest.
There will probably be a photocell or 2 (waiting for decision). The feed will be run to an external juntion box then to the photocell then to external junction boxes from which each luminaire will be connected.
Glands etc naturally
I think SWA is overkill, Hi-tuf possibly but was also considering 3183TRS Rubber coated flex.
I am unable to decide and would like some advice from those of you with a little more experience than myself
Cheers in advance
Cheers in advance
