- Joined
- 5 Oct 2009
- Messages
- 60
- Reaction score
- 6
- Country
I'm replacing my current Kensington 100E farmhouse style electric oven rated at 14.5kW with a double oven and induction hob rated at 6300W and 7200W respectively.
Currently the oven is fed from a 45A mcb in to a 45A dual cooker connection unit + socket. Can I take 2 feeds from this unit or do I need to run a seperate supply to the hob?
As I've had no issue with the current set up which is 1kW higher load I'm assuming all is good?
Running a new cable is a big job.
Thank you
Thank you
