As you say, black with the blue and red with the brown.
Good lord!! my sons model railway is up there!Why does thisn always happen to me??.
You need to get up into the loft and lift the boards I'm afraid....
the blue thing is the plastic wall plug(rawl plug?) where the screw went to hold the light fitting to the ceiling,thanks xThat might even be a blue thru crimp, which would explain why a 1.0mm² wire has pulled out of it.
For a lighting circuit wired in singles like the one in this thread, I'd expect to see two neutrals at all fittings except the last on the circuit.
I do hope that you are doing all of this WITH THE POWER OFF?
I take it you have checked all lamps (bulbs) are ok?
Is the lampholder part of the pendant in good order ie good connection, lamp making contact with the pins?
I SWEAR,all I did was take the old light down!! just checked in the loft, there is no box, just grey wires that lead from somewhere,and go down into the ceiling.Theres nothing poked thru up into the ceiling,and nothing disturbed(except me...) God knows what happened. will have to admit defeat and ring "sparky" Can't understand why the spare room lites not working???admit it, you've chaned a light switch too..
or you have fuses and wired it up wrong and blew the fuse but haven't realised it.
