Cat 5e or Cat6
8 Mar 2010
What ho one and all,
Will be getting fibre to the house in the near future and want the ONT in the loft. Have managed to get a CAT6 cable from the loft to the ground floor 'office' space and will plug the router into the wall plate.
Bandwidth and speed is not an issue as only the two of us using the internet, no gaming, films, etc. Currently getting 35 Mb/s with fibre to the pole via a BT master socket so assume FTTH will be an improvement.
I have a selection of CAT5e cables and wonder if there is likely to be an issue using CAT5e for the last 2-3 meters rather than CAT6?
Thanks and toodle pip
Cat5E is capable of 1Gbps at up to 100m.
Cat 6 is capable of 10Gbps up to 55m and 1 Gbps up to 100m.
FTTP from most ISPs can range from 74 Mbps to 900Mbps with 1Gbps occasionally. Most ISP routers are 1Gbps switches inside.
Unless the router/switches and connected devices are 2.5Gbps capable nothing will be gained by using cat6 anywhere.
No amateur is likely capable of terminating and testing Cat6 to the 10Gbps spec anyway.
Good luck with getting Openreach staff into your loft space.
Thanks. I know about the loft H&S business so am designating it as the second floor. As an FYI, attached is an image of my dangerous loft. Given that Openreach will have to attach the fibre to the roof apex at the front of the house, at around 9m high, I can fully understand why a loft is so dangerous!!!
Couldn’t get ISP’s to fit new supply to my loft and it’s a bungalow, have you had any confirmation from installers?
