For 4 years and 11 months anyway.When its all over you will wonder what all the fuss was about![]()
I've checked in my CITB book and both them methods are acceptable.
There is another one though.
Who knows it?![]()
Are you meaning the method of checking the fsd on a fire with no b.p. test point from the meter?
The manometer tube over the cooker injector with 3 other rings going is the correct way, but you don't have to of course as if the manufacturer has not provided a test point they also won't have given you a burner pressure figure to check, but they will have given you a kw input to gas rate.
See..you do know quite a bit...the impression i get is you have all the info in your head but get a little stressed in a pressure situation.
