    Dismiss Notice
CCTV night vision distance and optimising lighting
Discussion in 'Alarms, CCTV & Telephones' started by YorkshireMidge, 15 Dec 2018.
  1. YorkshireMidge
    YorkshireMidge
    29 Jan 2011
    148
    Thanks Received:
    5
    Yorkshire
    Country:
    Are there any rules of thumb about night vision cameras and how far they are really effective, as opposed to what is claimed in the sales blurb?
    I'm about to replace an old camera I have. I need it to work 20-25M in pitch black as our wonderful council switch the street lights off in the dead of night to save money, and the street lights normally add enough light to my property.
    But I also need it to be smart enough to back it's IR off a bit when the street lights are on so it doesn't white out things that are near.
    Thanks!
  2. Sponsored Links
  3. sparkymarka
    sparkymarka
    16 Feb 2011
    8,078
    Thanks Received:
    1,227
    Sheffield
    Country:
    Whatever they say ...half it at least ...some things absorb ir light , some reflect it ...
    • Thanks Thanks x 1
  4. secureiam
    secureiam
    20 Jun 2014
    4,657
    Thanks Received:
    579
    Lancashire
    Country:
    some cameras IR is filtered out so you don't get the apparent bounce back.
    like advised to be safe half the values quoted allows for non optimal conditions
    • Thanks Thanks x 1
  5. YorkshireMidge
    YorkshireMidge
    29 Jan 2011
    148
    Thanks Received:
    5
    Yorkshire
    Country:
    Thanks for the advice guys. What I'm after then is a good quality/brand grey coloured HD-TVI 1080P bullet camera with 2.8-12mm manual zoom to mount to the soffit board (i.e ceiling mount), and by the sounds at least 40M night vision. I have a couple of Twilight Pro HD-TVI dome cams covering other areas of the property which are pretty good but have only 30M IR. Have a couple of Hikvision cameras which are pretty good too - but they don't seem to do many cameras in grey. Any thoughts appreciated. Thanks.
  6. steveo44
    steveo44
    29 May 2010
    268
    Thanks Received:
    21
    Nottinghamshire
    Country:
  7. sparkymarka
    sparkymarka
    16 Feb 2011
    8,078
    Thanks Received:
    1,227
    Sheffield
    Country:
    They do the above in a grey eyeball version
    • Thanks Thanks x 1
  8. YorkshireMidge
    YorkshireMidge
    29 Jan 2011
    148
    Thanks Received:
    5
    Yorkshire
    Country:
    That looks ideal actually. I could get to the OSD menu on my Twilight Pro cameras without any difficulty - but I'd not worked it out with my Hikvision ones, until a few minutes ago! So should be OK with the motorised zoom/focus on this. Problem solved hopefully. Many thanks!
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
