I am proposing to install central heating (two-pipe, un-pressurised system) but have a gas fitter and electrician do the boiler and electrics. I have sorted-out my preferred pipe runs and the feed and expansion tank location is fixed because it was part of my old system which will be completely removed.
I see that the feed from the new F & E tank is sized at 22mm also the Pegler air separator has a 22mm connection for the feed pipe. Would it be OK to use 15mm pipe between the two (with the correct 22mm/15mm fittings) rather than use 22mm throughout? I can see no reason that a 22mm pipe would be required and the old system was also 15mm.
Secondly although I know the connections for the Peglar air separator I am not sure if it has to be mounted in a certain orientation. Should it be with the longest section vertical or horizontal or perhaps it does not matter?
The Peglar ventair is marked
Waterflow/Airflow - inlet (horizontal left side)
Airflow - outlet (horizontal right side) to vent pipe 22mm throughout.
Waterflow - outlet (downwards)
The other outlet should therefore be the feed from the F & E tank. (downwards) which I think would be OK at 15mm.
